I just purchased a DP508 PVR from someone (used) and I hooked it up to my DishPro LNB and the receiver will only find the 119 Sat. I have tried a Legacy LNB and also a DishPro Plus. All seem to do the same thing. When I go into the check switch with the DP LNB it only goes trough 1 of 2 tests. When I view the details of the test it says that it found 119 and that the other one is connected but it can not find the 110 Sat. I know that the Dish is aligned correctly because my other DP301 is working correctly. I also have tried two of the DP508 PVRs, both do the same thing.
Please HELP!!!!!!
Thanks,
BS
Please HELP!!!!!!
Thanks,
BS
