Do I need a mutiswitch?
maxamus1975
28
My basement is currently under construction, but I would like to start planning my home theater setup. I want to run two RG6 cable into the basement, to hook-up a HD DVR but I’m out of ports on my sat. My current Slim-line 5LNB sat only has 4 RG5 ports which are all being used. Should I call D* and order an 8 port mutiswitch, or is there another way around this? If I order a switch, can it be installed in my garage? This would make my life easier if additional runs are needed. Thanks in advised for your help.:)
The Zinwell WB68 would do the trick I believe. If D* is going to eventually hook up your new system, they'd provide it for free. If you're adding another location w/DVR they may do the upgrade for free assuming you acquire the new hardware from them. HTH :cool:
One thing to remember is that all four lines coming from the dish need to connect to the inputs on the WB68 and then 6 of the outputs from the WB68 will connect to your receivers. Just wanted to mention that so you have all the cables routed correctly.
3 FSN HD launches delayed: Ohio, Cincinnati, Florida
Is D* right for me?
