Although Neither dish nor Direct Tv carry your local channels, you do have two. ABC channel 47 (WMDT) and CBS (WBOC) Channel 16 are both listed as a grade A signal - about as good as it gets. That means you can get these two stations with a reasonable outside anetenna, probably with good rabbit ears. So you will need a waiver from them to get a distant network. However, NBC and FOX have no signal in your area and you should be able to get those distants without any waiver.
