Bug list
I've posted my found bugs on the dbstalk.com forums, but haven't seen much in the way of confirmations. A couple of those things I have now confirmed by reading this thread. I'm posting/quoting all of those bugs here now (some of these also confirmed by 2 of my co-workers with 522s):
and...
and...
Kevin
boba said:What have you found for bugs or dislikes on the 522 so far?
The biggest problem I have had so far is the info screen popping up on Tuner2. I have also had it lockup with a black screen and aquiring signal once on Tuner1.
I have only done 4 recordings so far but all have had extra time added by the receiver so I had to skip over parts of the previous programs, to watch the intended programming. I don't have this with my 2 TiVos.
I don't like the lack of ability to change the numerical order that other receivers have in the programming guide.
I don't like the wider size of the remote it to me is less comfortable to hold and must be very hard for women who have smaller hands.
unix-guy said:1) I start recording a 30 minute show at 9:00pm (via timer or manual). I have another show that I plan to watch (on the same channel) at 9:30pm. At 9:15, I pause for 5 minutes. I then resume playing and watch the rest of the recording. At the end of the recording, I would expect to be able to just continue on watching what has buffered on the current channel (this is the TiVO behavior, but I've also confirmed that the 508 is the same) but no - I just lost the 1st 5 minutes of that show!
2) I have a timer set to start at 9:00pm. I start watching previously recorded show at 8:45 and finish at 9:15pm. The 9:00pm timer has not fired... The show status is "recording", but the record light is not on and it never appears on the list of DVR events.
and...
unix-guy said:Just now found a "new" bug (haven't seen it in 2 weeks of regular use):
a) Watching live TV, press pause and there is about a 1-2 second delay before pause happens
b) Press play and play resumes but without sound.
c) Press rewind/back and play continues (without sound still) although status bar indicates rewind at 4x
d) press rewind/back again, play continues but status bar indicates 15x rewind.
e) repeat up to 300x...
f) press stop. press play play resumes as normal with sound.
and...
unix-guy said:Yet another new bug/glitch. After the Super Bowl, when doing my American male duty of reviewing the half-time entertainment for "wardrobe malfunctions", I had this happen:
1) Watching pre-recorded show (Super Bowl)
2) paused show
3) Went into DVR Events menu (pressed * on remote)
4) while looking at my list of events, all the color "drained" from my screen until it was completely black & white.
5) exited menu and resumed play
6) color returned in a "reverse drain"
I repeated these steps 4 or 5 times and could reproduce the problem each time... Anyone seen this before?
Kevin
