Hi, I installed a dish1000/Vip622 last year and due to line-of-sight issues I cannot get 129 (or 61.5) signal above 50 reliably. I have peak'd my setup on 119, so 110 and 119 hit 82-86. Thats the best I can get due to trees. Now I am in process of installing a second dish to point to 129. Someone gave me a Superdish and is supposed to drop it off today.
Based on my location in Raleigh (35.77L x 78.63L) I think my dish settings for a direct shot at 129 should be:
244.17 deg
23.18 az
0 sk
My question is about installing the second dish. Since the Superdish has multiple LNB's should I use one LNBF versus another in order to center the beam on the LNBF? Can they be paralleled in order to gain signal strength? Do I need a switch? (Dont think so, I just connect the second satellite to the 110 input on the original dish1000)? There are tons of trees here and I dont think I am going to get an easy shot at 129.
I think its overkill to use a Superdish, but with the trees I think the larger size will help get a good signal. Please let me know if I'm on the right track? If the Superdish doesnt work, do you have any suggestions (other than moving my house)? Are there larger dish's which would work better? If so, can I use the Superdish LNBF and just swap the dish?
This forum is excellent. I've been reading and the experts are great and really helpful. Ive learned alot already. Just need to get over the final hurdle...
Thanks, Tom
244.17 deg
23.18 az
0 sk
Thanks, Tom
