Dish Receiver 322
posmcop
tennessee
I have a DP Quad lnb and want to hook a 322 receiver up to run two tv's . Can this be done and how. Thanks now for any help.
As long as you are only looking at 119 and 110, it should work. Each 322 Sat Input will require a separate cable run from the DP Quad LNBF, one for each tuner. So, that means ports 1 and 2 of the DP Quad LNBF runs to Sat in 1 & 2 of the 322 at the 1st TV.
Now for the 2nd TV: Run a cable from the TV2 OUT of the 322 to your 2nd TV, and tune the 2nd TV to the channel being output by the 322. It's been a while since I have used my 322's, but I do recall that you can select the TV2 channel to be sent to your 2nd TV.
Is that what you were thinking of?
TV2 is usually set to off-air channel 60 or cable channnel 73, but you can change the format and/or channel number if needed
Neighborhood power lines in line-of-site a problem?
Dish Network service in Dominican Republic & HD
