You have to delete the timer and recreate it using a specific episode if you want to just DVR that one channel.
Seek will record any episodes not recorded from any channel.
makes sense, some of the search led to VOD, thus i was unable to set a timer. others said would you like to record when available, that was nice. others had a vod or record when available, and some of those the record was broken, and led to nowhere. the other catch, is the show may be running repeats on a different channel, and the timer will want to set a dvr type from the search for the channel new shows will not be on.
is there no way to change the TYPE of timer from dvr to seek ?? that would be nice. especially for racing type stuff, and shows that seem to move channels ******* under the summary screen record series, then i change to new only *****
thanks again
*** Just found that if i go to show summary, it may let me make a seek timer. seems to be working, did my motorcycle timer from that screen.
didn't work for walking dead though (gave netflix and vod options, no record though)
not bad, only missing 2 timer out of say 100, most shows not airing at this time, the search and summary worked great !!! many are seek (set off the summary screen) others are dvr set off the episode screen.. took some time, but the results seem very good. ***
