Here are a couple of questions actually..
1. I have seen somewhere here or somewhere else that some have reported that they can get a reliable signal with their TV's OTA tuner but when they try to use the OTA tuner on their Dish receiver, it just isn't as good. I suppose I am asking a question about sensitivity.
I have two receivers. A ViP211 and a ViP722 that I want to use for OTA and I am a very rural area. I am about 85 miles from the NYC towers but high on a mountain and about 75 miles from Scranton, PA channels.
Of course I need one of the best antennas I can find along with a pre-amp booster and if I want both cities, I will need a rotator which brings me to question number..
2. Will I need to re-scan every time I change the direction of the antenna or is there some way for me to manually put in channels I am looking for? Another issue is both cities have a channel on channel 11 (once June 12th comes). Can the receivers remember the both channels 11? Of course I realize that if I am aimed at Scranton I will not receive WPIX from NYC and I will not get WBRE from Wilkes-Barre, PA when aimed at NYC.
The weakest channel I am trying to get shows up on TV Fool at NM(dB) -13.6 and Pwr(dBm) -104.4. The way I figure it, I need an antenna system that will give me a 15 dB gain across the board from channel 7 and up to get that NM(dB) value above zero. BTW.. this weak channel was very easy to get years ago when all I had was an OTA VHF antenna but now I need to play with UHF as well. Antenna system recommendations are welcome as well.
The signals must be received by the Dish receivers as my TV's are only "HD Ready" and do not have built in OTA ATSC tuners.
