I might be wrong on this but I believe in order to provide HD-LIL both E* and D* have to go back to each station in your area and get permission again to provide you with that station's HD signal. This is also the case with National HD-LIL and each of us getting a waiver from our local stations so that we may receive the National HD signal from E* or D*. Has it been shown that the SD waivers will work for HD?
Secondly, and more important, ABC cannot override its affiliates with programming from E* or D*. Since local affiliates do own their 'territory' they have control over what is shown by the National Feeds in their area. Several times in the past few years in differant parts of the country the local affiliate refused to show the National Feed.
I state this because this issue with ABC showing the Superbowl in cities where they own the station is a simple contract where trying to beam in a National Feed over a local affiliate who has control over their market is a very difficult one. Since ABC only 'owns the territory' over the stations that they actually own outright they can only do a contract for those cities.
Blaming E* or ABC is a waste of time. If you really want action, you must immediately pursue your local affiliate. You must ask that the local affiliate contact E* and ABC and allow the National HD feed into their area. You must also explain to them how they are going to share in the advertising revenue when their signal is not the one you are watching. And what does that mean for local advertising leading upto and after the Superbowl? When you have those answers in hand and a whole lot of folks in your viewing area up in arms and blasting away at the local affiliate then you may be able to get that HD signal beamed into your home.
