Any idea if it is possible to keep things recorded on the Hopper separate from what was recorded on the Joey so one user doesn't have to sift through another users recordings?
the joey's and two hoppers can pick between the six tuners or the pre-existing recordings.If I have two hoppers and 3 joeys I assume each joey can pick and choose which tuner or recording from what ever hopper I pick? Or does a joey have to be "tied" to a specific hopper to see its content?
If you add the sling adapter, you should be able to watch on your computer. Maybe some 722 owners could chime in there as i don't have any experience with sling.Since the Joey is a client device, other than MOCA for it's connection to Hopper, could one use a computer as a client? Would (could) Dish create a client app for Windows Media Center (and Apple Media Center equivalent) that would let a PC act as a Joey?
A lot we don't know yet.HIC Question:
I don't understand why this extra device is necessary in the system. Is it simply a Moca/Ethernet converter? If so, it certainly would be easy enough to build that functionality into the Hopper.
If the HIC is required for BB access, what is the Ethernet port(s) on the Hopper and Joey for?
It would be a much easier setup, if we could just attach the Hopper and Joeys to the Node/Switch, and the Hopper to the Router.
The Joey has no separate tuner in it (it uses the Hopper's tuners) so anything recorded will show up on the hooper
In the video, the first Ethernet port on the Hopper is clearly connected and active. So, that works. And, if so, I'd rather connect to my LAN using that or a wi-fi adapter than an additional device and cabling.Scott has said the Joey ethernet port will not initially be enabled and Joeys must connect via Moca.
Imagine the time saved per installation, if the Hoppers and Joeys could connect to each other and the home network the same as ATT's latest U-verse boxes do, using any combination of Moca, Ethernet, and Wi-Fi? That would be the way to go.
With houses built today with a home run in the garage or elsewhere, just locate the node in the home run box, run one cable from the dish, put the Hopper in the living room and put Joeys at the other TVs, connect one cable at each location, hook up the ethernet and you're done after booting and downloads, etc.
Since the joey is a thin client, it would be fairly overkill from a hardware persepective, but could make for a nice mix.
