Dish and cable setup for install next week
mike_ayu
22
I'm having an install done on my house next week, and want to make sure I have the wiring needed (based on some really bad experiences, I won't let anyone else do wiring on my house - so far the installers I've used have been very very happy with the wiring setups I've done.)
I'm getting a 942 and a 625 with HD pak & VOOM channels. D* wouldn't commit to giving me a Dish1000 receiver (I'm in the San Francisco area, so I think it will work based on another thread.) And I currently have 2 cables run from the room to the cable distribution box.
If they don't give me the dish1000, they said they will install a second dish - if they do this, will I need more than the 2 coax cables from the roof?
If I can get them to switch the dish1000 after 9/27, would I only need the 2 cables?
Those 2 lines will work fine if they use a dish500 with a DPP twin LNB. They can add a m/c dish pointed to 129 or what ever and switch it thru the DPP lnb.
I think that route will get you the best signal on 129 anyway, having focused in on one bird rather than balancing 3.
You'll be fine with DPP.
More likely, 2 Dish 500s (1 with a dual LNB, one with a twin) -- I haven't seen a 500+300 setup in a while. Your wiring should be fine, but if you need any well, I wouldn't worry too much, most of the dish installers are EXTREMELY good about this compared to the comcast installers out here (good lord, getting them to run a line from their drop to one of my jacks was like pulling teeth, except worse!)...
Best of luck with alladat!
Potential problem qualifying for HD Networks when available?
Recorded DVR portability.
