Error via Quote:
Okay I am going to try my best to make this as detailed as possible. Looking through a lot of the forums already made about the Sling adapter, I have only found a few forums that may relate to my problem but no real fix for it for my specific issue. Here's the low down:
Cannot seem to connect to the sling adapter on the same network via DO (DishOnline) that the Sling adapter is connected to; however, Sling adapter works perfectly fine on other networks as it should, so it's a localized/in-home network issue but I cannot locate the problem to fix it.
I made sure all the specs in order to run the Sling is up to date.
Specs:
Receiver connected via Ethernet Port directly to Westel Router
The Sling Adapter works properly on other networks, just not on mine. What that means is that I cannot connect (WiFi or Wired) to the Sling on DO (DishOnline) on the same network that the Sling Adapter is connected to.
Now I can pull the log file from the Sling Adapter but I don't know how to read it to see what type of error it is showing so if you need the most current log file to view, if it could help your case, you can download it via TXT on the attachment below. It is the most recent/current log file (raw, not edited).
I'm not sure what other information you need but what I am trying to do is to get the sling to work via my home network which there seems to be some kind of communication problem between my router and the receiver. Any help would be greatly appreciated!
Thank you to those who read this and very much thanks for those who wish to help me on this little challenge!
~Caltosy
Your computer was able to connect to your device, but the connection was interrupted. (Error 36)
Please try connecting again.
Specs:
Windows 7 Home Premium 64Bit OS
Google Chrome 17.0.963.78 m
DISH VIP722K HD DuoDVR
Westel D90-327W15-06 (FW UpToDate)
Frontier Communications DSL (3.5Mbps/.7Mbps)
~Caltosy
