As I mentioned in a previous thread, I am going to be installing a Dish 500+ with a VIP 222 receiver. I will be using a DPP33 switch. I will hookup the 3 cables to the switch as indicated in the manual and then run one cable to a DPP separator so both tuners can be used in the receiver.
I plan on using the signal strength screen in the receiver to align the dish. The manual suggests aligning the 119 satellite first, can someone tell me a proper transponder I can use to check the signal strength as I am aligning the dish? Also, should I be able to check the signal strengths on 110 and 118.7 as well from this screen or do I need to run the check switch first?
For anyone who has done self-installs before, do you think I would get any benefit from using one of the cheap analog signal meters, or should the signal pointing screen be sufficient? I do have experience with installing FTA Ku and C-band dishes and the older DirecTV dishes.
Thanks,
JB
Thanks,
JB
