Diseqc robs signal
Only thing I'm worried about is attenuating my C band signal. Then I'll have problems with that.
Your other choice is to remove the Cable from the Uniden receiver when you are not using it, this removes it from causing your problems. I use to do this before I inserted the attenuator. I attached a quick disconnect to do this on-the-fly.
Are you powering off all connected receivers when you swap cables on the switches? (either by unplugging them or by the REAR switch)? These switches are VERY sensitive to voltage spikes, and a port can be burned out easily...
Hey Tron, thanks for the reply. Yes I power off the receivers before swapping cables. I even tried different ports. It all seems ok if I don't hook up the C cable
I didnt realize they had quick disconnects for RG6. Learn something new everyday
Cyberhome ch-srd converter
Need help adding Hispasat feed...
