DIRECTV Transponder Map ~ Data 1/8/2025
They likely date back to at least the mid 2000s, since the SD feeds for TruTV (ex-CourtTV) and Pop (ex-TV Guide) have CCIDs 203 and 224, which match channel numbers they last had in 2007.
They conceivably could go back to before DIRECTV implemented their Advanced Program Guide (APG) structure.
  • Wow
Reactions: lordodogg
The patents that reference the CCID predate the existence of the Apple App Store and Google Play's original Android Market incarnation.
They use it to identify the records wherever they are used internally (i.e. signal monitoring and automation) or externally (i.e. online guides and apps)
  • Wow
I suspect they are used to configure your receiver as to what channels you are authorized for. We have not found anything in the APG records that links an individual channel to a package. And some LIL channels are only available in some narrow geographic areas. So they have to have a way to store a list of subscribed channels to your STB, perhaps on the access card.
DirecTV Satellite Transponder Updates for Jan 15 2025
Comparison of Transponder Data for Jan 15 2025 vs Jan 08 2025:
No changes in system tables for any transponder tuning parameters.
Stream (PID) counts:
LIVE Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
4​
HD​
276​
-1​
1450​
SD mpeg4
138​
196​
SD mpeg2
448​
RB​
Audio​
89​
Push​
30​
Slate​
21​
1​
TEST Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
HD​
1​
SD mpeg4
1​
SD mpeg2
RB​
Engr Work​
34​
Doctor J's Internet provider is down. I am posting for him.
The PID count Excel workbook provides much more count detail.
Newly updated tables of Streams on each transponder are available in the DataDigesters TPN Grids
More details of changes in individual channels will follow in the Weekly Analysis
and Gary Toma's Domestic TPN Map Excel files
A mostly quiet week
KWHY/22 Los Angeles was sold to the Church of Scientology and is now KSCN
9755 ACCESS - P+ Showtime info is now live
MGM+ and The First swapped TPNs slots and sats, FLIX also switched transponders
