Direct tv HD DVR Gennie 34 Series Manager Setup ?
Hutch1814 and others I got it to work on Networks for the recording No repeats thanks
Hutch1814' Your the one with the DIRECTV: Genie (HR34) ? could I PM with more DIRECTV: Genie (HR34) questions or should I put em here ?
If you post them here, others can learn from your experience as well.
Jimbo should I start another thread for my other DIRECTV: Genie (HR34) ?
Hutch1814 on a DIRECTV: Genie (HR34) "To record episode press R on your remote control" annoying popup is this on all DIRECTV: Genie (HR34) ?
I have a HR34 Genie and have never seen that pop up. The only pop up regarding recording that I have seen is the "press R again to record series" message when you set something to record.
on a DIRECTV: Genie (HR34) "To record episode press R on your remote control" annoying popup people say you have to set 5 programs to continuous recording and it seems to stop popping up anyone heard of this ?
You've posted about this on all the forums. You've been told several times how to get rid of this by setting up 6 series links. You just seem to ignore what you are being told.
Iceberg For Directv HR34 Genie DVR. If I record from Sept. to May without watching till May, how many series can I record at about 24 episodes a series(some 1hour & some 1/2 hour) without filling up storage capacity.
Directv HR34 Genie DVR. Questions
on the Directv Genie HR34-700 with HD-GUI dose it say on the guide if the show is New
There's no way to quantify it in those terms. It's one terabyte of storage. HD, SD, OTA all effect file size. I would venture that 720p vs. 1080i matters, too. Note: I would certainly not recommend waiting until May to watch everything - One crash and it's all gone. And with my HR34, if it gets to be less than 75 to 80% on the DVR space, it becomes even slower and messes up more.
To see if a show is new, select more info and look at the first air date. This is not given for all shows. That hasn't changed since you asked it the other day.
ejb1980 sorry I meant for the Directv Genie HR34-700 with HD-GUIDE dose it show new like a regular TIVO dose ?
To see if a show is new... look under "more info" and it will usually say the date it first aired. If the date it first aired is today, it's new. Otherwise, it's not new.
My Directv Genie HR34-700 is acting strange My Set up is first run only all episodes keep until what it dose is keeps recording repeats when it should not and the other thing it dose is when it dose record a new show and their is the next new show it dose not record at all maybe this Directv Genie HR34-700 is messed up for me should I ask to have replaced ever hear of this ?
I am aware of your issue. I read it the 5 times you posted it in the other thread. Myself and others told you that if a show is not properly tagged, it will probably record. What shows specifically are you having this issue with? What channels? My HR34 has done this and others told you the same. I have seen cable DVRs do the same thing.
Also:
Dose: a dose of medicine
Does: it does not record
Also:
I've been recording "America's Game" on NFL network for months and not a single one is even set to record on my DVR, it's a weird glitch that happens all the time to people. And ejb, thank you! I was gonna throw the correct spelling in there as well ;)
as noted above there is no "Real" answer. If its in HD it will take up more space than SD. If you record a HD channel it takes more space up than SD
