I have a motorhome set up with HD TV using a HD receiver/DVR. Using a automatic locating antenna on the room. Works Great. When at home the motorhome is parked under a overhand. The roof antennas cannot be used. I had a single cable installed with an input jack available in one of the bays. The antenna signals are run to a 4 X 8 switch. There was physically only room ro run 1 cable which is now feeding tuner 1. I have a signal level 0f 99%. I cannot get past the set up display because it is looking for a signal for tuner 2. which is obviously not connected. I wanted a signal to the receiver so I could keep it "alive". It would be nice if it could be viewed also.
Question - Can I run the one cable to a splitter and run the 2 outputs to the Direct TV receiver? One to tuner 1 and the other to tuner 2.
any input would be appreciated.
GeraldR622
GeraldR622
