Diplexer Problem
cobraman
45
I just hooked up a Terk BMS-58 Multiswitch. Everything with the sat feed is OK except when I get to the Sony HD200 box and use the Terk diplexer to hook the UHF antenna to receive HD channels. When I hook both cables to the diplexer, I get nothing. If I take one off, the other one works. I used the DC filter and can get the sat and UHF to both coexist on the diplexer but almost all of the HD channels that I can get without the diplexer and when I disconnect the sat wire are gone. :confused:
Has anyone ran into and solved this problem before?
On the Diplexer there are two paths, one has a solid line from input to output this is the side that goes to the Sat In the other goes to the Atenna In. Be sure you have a Di Plexer and not a standard splitter. There are some Satellite Slitters that will work again the solid line from in to out is the DC Path for the Satellite.
What's Behind the Pegasus Stock Rise?
Straight and Simple: D* or E*?
