I'm going through things right now to try to figure out why I"m off the arc and I decided to read the DG380 manual to see if I am missing something.
When I got the motor and installed it, I set the elevation scale (the motor bracket/motor elevation markings) to my latitude of 35 deg, thinking this motor was like my other motor, a stab.
When I read the manual, I can't help but think it's saying to use the Elevation and Declination Angle Table leaflet to find your elevation angle to set it at.
Looking at 35 deg site latitude in the leaflet, it says the elevation angle is 55 deg.
Should I keep my motor set where it is at 35 deg or use 55 deg on the scale of the motor bracket/motor elevation markings?
If I"m fine, then I have to look at polar axis things and dish bracket elevation (WAG there since I had to invert the fortec star 90cm bracket to work with this dg380, but I did find my due south sat and peaked it up but my arc falls off about 20 deg to each side and first thing I checked was that my pole was plumb).
