The CMOS (copper metal oxide) chip is for computer setup, at boot, that establishes what things (COM1 e.g.) are connected. Com1 is working there and in further system check.
Iceman's instructions to Jayt224320: "attached is the loader. You'll need that.1. hook up the cable from box to receiver. 2. Open up loader. 3. power on receiver. Make sure it is on. 4. Open up firmware you got from Coolsat site ( make sure to unzip it). You'll scroll to "all files" to see the file. 5. press start on computer. 6. power off box with switch on back and turn right back on,
Box will download newest software. DO NOT turn off box again until it is completely done and cycled through. The computer will say done about 30 seconds before the software is done in the box."
Downloaded Ice's loader and update 9A update for CS8000 from Coolsat. I followed instructions to the letter, and, later, every variation thereof I could think of, including your suggestion.
What I get is this, (and I have a licensed copy of mscomm32.ocx): Ice's loader v3.01 gives screen which has "Download" and "Firmware" checked. However, COM1 is checked BUT GREYED OUT. The loader accepts the Coolsat update fine. At the bottom of the screen are three tabs (Port Open, Start, and Stop). When Start is pushed (receiver is fully on) then off/on, absolutely nothing happens except the whole screen goes grey, and the receiver goes "Ld" then "---" then "Standby". It will not take the update no matter what tricks I try.
Tried this on a new 128bit computer I just built and thoroughly checked. Exact same result.
I do have some some computer/sat knowledge, and have uploaded and downloaded various components hundreds of times. Tried all my "back doors" to get this to work.
Exact failure in two computers, tells me that this is a software problem. Receiver does pick up and broadcast 3 locals. C0M1. box should be black, not grey. Interestingly enough, if you press the bottom left loader screen button it changes to "Port Closed" and everything changes to proper black. On "Start", though, you get the 8018 error message.
Incidentally, Coolsat is Worthless!!. The same guy answers both the Support and the Repair telephone. He admittedly has no tech knowledge at all. He just repairs receivers. Can't get to anyone else, "Send it back and we will repair it - in 4 weeks"
Finally: I'm sorry about the 2 threads. Was new, and 8018 error was a computer error, not FTA. Thought some hacker out there might know, Fixed it myself. Present error message is legit. (can't download from a closed port). Will stick to this thread from now on. Equally very sorry to be so long winded. Hate it, but necessary. After about 15 hours, I'm at a loss.
Do you know where I can get another loader? Can't do anything about Coolsat's update.
Again, my sincere thanks for your time and interest.
