Sorry if this is a stupid question.
I have a 222 that is connected to the LNB via a DPP44 switch. Where the switch is located is where all of the wiring in my house terminates from each room. Instead of running a separate coax from the receiver to a second TV (not a pleasant option to re-wire through walls or leave a cable on the floor through hallways!), is it possible to send the TV2 signal back through the incoming coax (the coax that brings the signal from the switch to the receiver) through diplexers to where the switch is to connect directly to the cable that runs to the second room?
If this is possible, can you explain how it's done and if there is any specific type of diplexer to purchase? Thanks for any insights here!
