I finally purchased a Motec SG-2100. Set-up was about as much fun as finding 10r with a warped pan. After spending about 2 hours in 35c (104f) sun on a flat tar roof it came to me that I should try using a circular LNB to dial in the motor. I replaced my linear LNB with a spare circular, entered my USALS information then went to 91.0w and fine tuned that signal. To test that I had the proper arc I then checked both 61.5w then 119.0w I knew If I could get those then everything in-between should be fine. I replaced the circular LNB with my linear and It worked like a charm and I had everything running in about 15 minutes with just a little fine tuning to get the strongest possible signal on the transponders that had channels.
Also, I had purchased a magic bracket 4 hoping to receive multiple satellites without the need of moving the motor. I was running out of sunlight and wanted to get running quickly so I added 10o to all my sat position for circular satellites only then stored those positions set-up a circular LNB 10o left of the centre LNB on the magic bracket until I found the strongest signal. I tried to get it at 4o so I could get 123.0w and 119.0w for NASA but again I was out of time. I know I could just go out and buy an Invacom or a dual circular/linear but it would have just taken out all the fun.
