Thanks All,
I will be installing the pole support myself. I have an installer coming the day after thanksgiving. I have major line of sight issues, hence the pole install. After consulting with the installer and determining what is the best location for the pole I will have to reschedule the install. I will also install the required cabling to the feed, splitter, whatever you call it, which is already attached to the house. This was installed during a prior Direct TV installation and the old dish is still on my roof. I already have coax cable run to 3 locations in the house, but I will only be hooking up 2 tv's one with HD DVR receiver, and another plain HD receiver. Distance from the area where I think the dish could obtain a LOS to the house is about 40' to 50'. I will be wanting HD with local channels as well. The contractor from comcast actually ran the previous coax cable under ground through a thick, garden hose, type of conduit. If I have to run 2 lines the pvc would probably have to be 1/2"? Or would anyone of you suggest bigger?
Bryan
