Closed captioning in HDNET 9422
jb1945
SatelliteGuys Guru
138
Sacramento, California
Closed captioning appeared today about 8:45 am. Thought I had accidentally pressed something on the remote to call it up. Unable to turn it off. Checked several other channels, no CC found. Anyone else see this situation? Could HDnet be sending the signal with CC?
So you went to the menu for CC and it says off? Or you can't find the correct menu?
Update. The problem is corrected. I think the signal was being sent with cc visible. Now that the two travel shows are done, cc is gone.
I see them too. Must be something on their end.
Yeah, it is showing in guide mode so must have been embedded in the programming. The worst part is the placement of the text... sometime right dead in the center of the screen covering people faces.
I wonder if it's part of Dish's screwing with HDNet's signal, dropping the bitrates and resolution?
811 reads TP but won't lock on signal screen
Resolution and bitrate chart
