changed out 510 for 612.now my satellite won't work
jefdschnitzler
5
I just upgraded receivers hoping to add hd to several rooms in my home.unfortunately I can't seen to make them work. They say partial signal loss...no hd at all. Any thoughts?
Sounds like u need to call customer service and have ur receiver activated and a hit sent for programming. You definatey need the hit sent. Might also try pulling the card out waiting about ten sec and put it back in.
What markings are on the lnb's, no marking is Legacy, DP is DishPro and DPP is DishProPlus. In order to use the Separator, your lnb's need to be DPP. Did you switch out the receiver or did you split off the line coming in from the 510 to more than one receiver? Did you call Dish to activate the new receiver?
Please share the resolution with the community! Otherwise, only you are the wiser.
Missing channels
