Well, DUH, this is a satellite tuner/DVR, the OTA recording capability is a perk. Not having a second OTA tuner is not a missing feature.
Let's see, there are 4 major networks, we need 4 OTA tuners in a satellite DVR receiver.
What company provides 2 OTA tuners along with two sat tuners? If you need more OTA tuners, setup an HTPC and put 4 OTAs in there.
I barely have enough time to watch what I record off the three tuners that I have already! How do you have time to employ 4 or more tuners simultaneously and then watch all of that?
I pick two or three shows to follow live and I get the dvd sets for the others that I did not follow. Just now watching Without A Trace. The upscaled dvd episodes look great on my 90" screen!
The TiVO Series 3 has 6 tuners. 2 analog cable, 2 digital cable, and 2 OTA tuners. You can record two things at a time from any combination of sources while watching any other from the DVR.
Cable companies almost always offer local HD stations, so it's possible to record two HD local stations at the same time. *** These are not OTA though and as you admit, not everyone gets HD even from cable***
The DirecTV receivers also allow this, plus in Indy D* offers Indy HD locals, which Dish does not. ***Dish DOES allow you record up to 3 HD channels at one time, if you have LiLs in your area so it's not something Dish CAN'T do, it's just no possible for you at this time. Go do what you can do.***
Sounds like you need a Tivo Series 3 then.
The drawback to that is that the Tivo is only recording in mpeg2 and it can only record two events at one time while I can record 3 events AND watch 2 already recorded events simultaneously.
Like everyone else, you have to match service and equipment capabilities with your needs.
As I said earlier, you can setup an HTPC and record as many OTA events simultaneously as you want, something cable and DirecTV cannot do, not just Dish.
Actually, the S3 can handle MPEG 4.
It's moot now anyway. I "moved" to Atlanta last night and I'm quite happy.
As far as I know, it will play mpeg4 but not record it. Regardless... go record some LiLs!
I have the same question, the original person asked.... Can I record one HD program and watch another HD Program. As per my telephone call to Dish, they said that I would only be able to watch one HD program or record it while the other would be in SD mode. How is a person able to watch one HD program and record another HD program? As the quick facts state here: "View HD or SD content on TV1, and TV 2 you have SD or down-converted HD". No where does it say, Record HD on TV1 and watch HD on TV2.
You are confusing tuners with outputs, which is not uncommon since Dish has used the same nomenclature for tuners and outputs.
The 622 has three HD tuners, two are via satellite and one is an OTA ATSC HDTV tuner. They are named TV1(OTA), TV1(SAT) and TV2(SAT) parenthesis added. All three tuners can record HD simultaneously.
The 622 has 2 outputs strangely called TV1 and TV2. TV1 outputs HD via hdmi and component ports and SD via s-video, composite and the agile modulator (RF). TV2 outputs SD via composite and agile modulator (RF).
Depending on whether you are in single or dual mode the tuners are linked to outputs in various ways, but anything prerecorded off any tuner can be played back to any output.
Then, how do you record something in HD-TV 1 and watch something else in HD-TV 1? When I tried to record something in single mode, it would still record the program under SD-TV 2.
