just setup your viewsat receiver to receive c-band
a lot of us add a seperate satellite listing in the menu for this but you don't have to .
just check in setup and make sure the LO is set to 5150 ( for c-band instead of 10750 which is for ku)
you can stay c-band only but there is a lot of ku up there too.
get used to setting up what you have first then expand out to ku
under each satellite's antenna setting in the view sat make sure the "lnb lo frequency" is 5150
you will not have the diseqc switch in the diagram just the splitter
Your analog receiver will control the movement of the dish and change the polarity from V and H.
