Can I install UHF/VHF antenna preamp with (Satellite) Diplexer
ccuser
105
can I install UHF/VHF antenna preamp with diplexer
I have dish Network VIP 722 receiver with OTA antenna for local channels. I am having reception issue as posted in another thread and I was recommended to get preamp to resolve it. I have finally got winegard AP-8700 preamp with 2.8db noise and 26 db gain. following is my setup
- RG6 from Phillips MANT900 VHF/UHF antenna to diplexer(1)
- DISH 500 & Dish 300 to DP34 switch
- One cable out from DP 34 to directly to 722 tuner(1)
- One cable out from DP 34 to diplexer(1)
- One cable out from diplexer(1) to diplexer(2)
- diplexer(2) to OTA tuner of 722
- diplexer(2) to satellite Tuner(2) of 722
I am already running 2 cable to Satellite (since I didn't have DP PRO lnbs), I don't want to run third separate cable for antenna therefore I have been using diplexer.
Now I got pre-amp with its own power supplier, can I simply install preamp by antenna and power supply between cable "-diplexer(2) to OTA tuner of 722"
I recommend against diplexing (it reduces signal on both OTA and sat) , but if you must, you may.
You must place the power inserter for your pre-amp before the signal enters the outside diplexer or your pre-amp will get no power and you get no signal at all.
I do believe that either Channel Master or Winegard makes a pre-amp that uses satellite voltage to power the pre-amp.
I recommend against diplexing (it reduces signal on both OTA and sat) , but if you must, you may..
Yeah, I agree but I am getting too many cables running in single room.
Is that mean I have to provide power outdoor?
How do I do that? I am using AP-8700 pre-amp
Diplexers may be what your problem is, they reduce OTA signal. Why not spend the money on a DPP twin, then you can have one cable for sat and one for OTA and dump the diplexers
Question about a new antenna
VOOM question
