Can a DP21 and a DP Plus Twin combine to get 4 satellites?
SummitAdvantageRetailer
665
East Coast
Guys (and gals),
I haven't tried this before but is it possible to add a wing dish to a Dish 1000 by using a DP21 switch with the DP Plus Twin LNBF to get the following 4 satellites? Namely, the 110, 119 and 129 from the Dish1000 and 61.5 from a wing dish. Thanks a bunch!
I don't think so, the DPP Twin is only compatible with DPP Switches. However, I believe I read that it was also compatible with the DP34 provided you added a power inserter from a DPP44.
http://www.solidsignal.tv/dishnetwo...allation_Considerations-DP_Plus_Twin_LNBF.pdf
However, if you can feed a DPP44 and a DP Dual into a DP21, it seems like maybe you could. But then I would wonder if the power requirements of the DPP Twin would damage the DP21?
The moment you connect a switch to the DPP Twin, the satellite IN port is disabled. So, NO a DP21 won't allow you to get 4 satellites. You'll need the DPP44 switch.
Any way to tell if E* gets your locals via fiber or OTA?
Closed captions and NPS
