C-band dishes
C-band frequencies are downlinked between 3.4-4.2GHz. KU-band frequencies are downlinked between 10.7-12.75GHz. The higher the frequency, the shorter the wavelength. To reflect the same amount of signal on a longer wavelength the reflector size must be larger. To reflect the same amount of signal on a shorter wavelength (higher frequency), the reflector is smaller.
Reactions: spongella
Best Satellite Finder 2015
