Still having difficulty getting a READABLE signal. I think I got AMC 3? at ~136 deg georaphic [lat 47.8N lon 122.2 W], and the skew acts normally, showing I do have a linearly polarized signal. Peaked signal, could not get any quality, scanned all transponders on all visible satellites (LO 10600/22 kHz ON,) nothing detected.
The Tech SAT LNBf seems to be working, but the dish (parabola surface) was noticeably, but not severely bent in shipping several years ago. The amount it was bent seems to be significant as demonstrated by the weak signals I can see (~ 1-3 dB above the noise floor)
Any ideas to get it to the right shape? My wife will mutiny if I order a new 36" dish!
Let's see... 12 GHz radio waves are EM radiation, same as light is. Therefore the same optical laws apply.
Lambda at 12 GHz is ~25mm. Usual shape and surface quality on telescope (parabolic) mirrors--a dish is the same but at RF wavelength-- is lambda/10 for a good image, lambda/4 for a poor image.
So, a non-offset (I think this also applies to an offset) dish needs to match the pareabolic shape and surface finish combined to at least 6 mm, and better 2.5 mm for good signal and pattern.
Lambda/4 gives a 90 deg phase shift, if you get towards 180 deg, you get destructive interference which reduces signal strength.
