Ok sorry I was wrong about the layout, because I opened mine, and it looks like yours inside. BUT..... My fan is running all the time like I said, not in high speed like at startup, but it's running. Maybe yours is cool enough not run, but mine ru7ns right now. Almost not possible to hear, but it's running!Mark_AR said:I don't mean to disrespect, but where do you get your exceptionally incorrect info?
My 622 has been powered on since 6:30 PM(roughly 6 hours)
#1: The fan is NOT running continuously.
#2: The fan is located on the RIGHT side and not on the PS side.
#3:THe fan rotates CCW to draw air into the right side of the unit and exhaust it on the left so cooler incoming air circulates through the entire unit. Doing it the other way would actually cause more heat inside the chassis by sucking air over the PS first.
Chassis layout:
Unless there has been a major design changes since the 962 became the 622 the following pictures are still accurate.(Taken about 12:00AM 5/22/06)
PIC1: Overall layout of components of the 622(962).
PIC2: Shows fan NOT running on my 622 that is currently ON (nearly 6 hours at time of writing). Pic was taken through the chassis slot on right side of unit.
PIC3: Shows my 4" fan fitting neatly into the space between the drive/UHF antenna pcb and the fan/tunnel. Tilted slightly, it pushes air down between the mobo and hard drive. I still have to finish the plexiglass cover to contain the airflow.
