I'm moving back to DirecTV and need to know if the mast mount (plate that is bolted to solid surface) on the slimline AU9-S has the same bolt pattern as the original triple LNB dish (Pase II Plus). I declined the AT9 dish install many months ago when the installer said he would not install it on my chimney due to be bolt pattern being much larger. I originally installed the 3LNB in '01 using the right masonry bolts and have had an installer and antenna guy both compliment me on my installation. I'd like to mount the AU9-S to the same mount if possible with a monopole.
Thanks!
Scott
Thanks!
Scott
