This is a special request item and they are not carried on the trucks. Maybe a few outfits might, but the vast majority do not. Good luck getting it free.This is the non penetrating mount that would be the easiest & (at least in my case) they actually carried them in the D truck for installs (free). Seems like what's free is up in the air anymore so is best to ask but I'm sure they could locate one for you. If you get it yourself make sure the mast is 2 inches.
If getting a clean solid install for all the joy of HD is important to you (as it is to me!) be ready to handsomely tip the installer. If you make it clear to him that you'll make it worth his while, BOTH of you will be happy. Forty or 50 bucks now will seem like very little for a job well-done.I am moving to an apartment that requires the sat dish to be inside the patio and not mounted to the banaster. what options do i have and will the installer provide what i need or do i need to get things in advance. please advise.
i have a direct southern view. patio is 15x6x9. it is an upstairs apartment. i will have the 5lnb dish. I have permission for the dish. i was told previously that a tripod would not hold the 5lnb dish. is this true? where do i get one that will if not. will bucket and cement work? what is a non pens?
Why wouldn't a tripod be strong enough to hold a 5lnb dish? As long as you put cinder blocks over each "foot" you should be alright.
Would you mind not divulging contractor pricing to customers. Thank you.Usually for an apartment you can use flat wire through the window. I use perfect-10 2" non-pen mounts and they have the mast assembled at the end not the middle of the mount and it stand 36" tall. I know I pay $42.99 each for the mount and $10 for blocks so I usually charge $80 for the entire setup. I have seen other people charge from $75-$125
