Anyone else having trouble getting ESPN (206) and ESPN2 (209)?
Dlycious
16
I'm guessing not, by the lack of a thread already, but even after rebooting, I'm still getting the "Searching for signal on Satellite In 1...(771)", but it seems isolated to only those two channels, at least that I've been able to find. They come in fine on 72 and 73.
Thanks in advance!
Guess I really am a newb. Not entirely sure what 99c means?
I've got 82-83% on both Tuners 1 and 2. Satellite is at 101 degrees.
If you hit the "+" label on the screen next to the signal readings using the arrows and the select button on your remote you can change which satellite to view the readings. Keep hitting select while over the "+" label until you get to 99c. While you are at it, check 103c as well.
103c is at 37-49% (doesn't sound good)
99c is 25-28% (even worse)
Is this something I can fix, or is this an install issue?
There is your problem, you need your dish realigned.
While you are at it, check channels 482 and 483 and tell me what the message on the bottom says
favorites filters
Some good programming?
