Any recommendations for an indoor antenna?
I provided all the details in my original post...
abc - yellow/vhf - 276 degrees - 23 miles
cbs - green/uhf - 293 degrees - 28 miles
nbc - red/vhf - 289 degrees - 25 miles
What affiliates are these? We need to look up the DT channel #, power, and antenna height.
sorry about that here is the info from antennaweb
Antenna Type Call Sign Channel Network City State Live Date Compass Orientation Miles From Frequency Assignment
* yellow - vhf KIII-DT 3.1 ABC CORPUS CHRISTI TX 276° 22.7 8
* yellow - uhf KORO-DT 28.1 UNI CORPUS CHRISTI TX 289° 26.8 27
* green - uhf KZTV-DT 18.1 CBS CORPUS CHRISTI TX 293° 27.3 18
* red - vhf KRIS-DT 6.1 NBC CORPUS CHRISTI TX 289° 24.5 13
* red - uhf KXPX-DT 66 IND CORPUS CHRISTI TX TBD 320° 17.1 66
* blue - uhf KEDT-DT 16.1 PBS CORPUS CHRISTI TX 277° 20.5 23
Not sure of your exact powers but I installed an outdoor CM4228 and have no issues with the DT channel 8 signal at 30 miles.
The CM4228 performs well at RF 13.
out of curiosity are you still looking foran indoor antenna or have these guys convinced you to fo with an outdoor antenna?
yes
I will not put up an outdoor antenna, I would possibly put one in the attic but due to certain issues here I cannot mount one outdoors
yes
All you can do is try... get the biggest gain antenna you can get. You'll need it in the attic.
If you are mounting in an attic be sure to pay attention to the dimensions. No sense in buying one that you can't use. you amy want to investigate an inexpensive indoor antenan though to see if it si adequate. If not just return it.
DC broadcasters start PSAs for digital transition
CM7777 Power Supply
