After some research, I made an attempt to get some info together to aid in selecting antennas for HD reception. Researching indoor antennas next.
Antenna Classification (from antenna-web.org)
SM – Small Multidirectional - Yellow
MM – Medium Multidirectional - Yellow, Green
LM – Large Multidirectional - Yellow, Green, LT GREEN
SD – Small directional - Yellow, Green, LT GREEN
MD –Medium directional - Yellow, Green, Lt Green, Red, BLUE
LD – Large Directional - Yellow, Green, Lt Green, Red, BLUE, VIOLET, PINK
General guidelines in miles (from antenna-web.org - mileage to towers)
Indoor 0-15 miles
Attic 0-25 miles (may need to go up in size to offset room attenuation)
Short range 0-15
Medium Range 15-55 miles
Long Range 50-70+ miles
Colors listed in CAPS– Recommended with an amplifier and Roof Top Installation.
Adding a pre-amp where recommended will greatly improve your reception and your ability to hook up more than 1 TV and with long cable runs.
Preamps
Channel Master
CM7775 UHF: 26db gain, 2.0 db noise
CM7777 UHF/VHF UHF: 26db gain, 2.0 db noise; VHF 23 db gain, 2.8 db noise
CM7778 UHF/VHF UHF: 23db gain, 2.2 db noise; VHF 16 db gain, 3.0 db noise
Winegard
AP4700 UHF: 19db gain, 2.9 db noise
AP4800 UHF: 28db gain, 2.7 db noise
AP8275 UHF/VHF UHF: 28db gain, 2.8 db noise; VHF 29 db gain, 2.9 db noise
AP8700 UHF/VHF UHF: 19db gain, 2.8 db noise; VHF 17 db gain, 2.8 db noise
HDP-269 UHF/VHF 12db gain (high input), 3.0 db noise
Antennas
Channel Master Multi Directional
CM3000A SM
CM3010 LM
CM2001 LM
Channel Master Small Directional (SD)
VHF/UHF
CM3014
Channel Master Medium Directional (MD)
VHF/UHF
CM3677
CM3016
CM3017
CM5646
Channel Master Large Directional (LD)
VHF/UHF
CM3671
CM3678
CM3679
CM3018
CM3019
CM3020
CM3030
CM4242
UHF
CM4221
CM4228
CM4248
CM4308
Winegard - Multidirectional
MS-1000 SM
GS-1000 SM
MS-2000 MM - Amplified
GS-2000 MM – Amplified
Winegard - Small Directional (SD)
VHF/UHF
HD7210P
PR7000
PR7005
PR7010
PR5646
UHF
PR4400
PR9012
PR9016
Winegard - Medium Directional (MD)
VHF/UHF
HD7210P
HD7078P
HD7080P
PR7015
PR7032
VHF
HD4053P
PR5030
UHF
HD9065P
PR9014
PR9018
PR8800
Winegard - Large Directional (LD)
VHF/UHF
HD7082P
HD7084P
HD8200P
PR7032
PR7037
PR7052
VHF
HD4053P
PR5030
UHF
HD9085P
HD9095P
PR9022
PR9032
Antenna Direct
UHF
DB-2 SD
DB-4 MD
DB-8 LD
43XG LD
91XG LD
Rick
Indoor 0-15 miles
Short range 0-15
Preamps
Channel Master
Winegard
Antennas
CM3000A SM
CM3010 LM
CM2001 LM
VHF/UHF
CM3014
VHF/UHF
CM3677
CM3016
CM3017
CM5646
VHF/UHF
CM3671
CM3678
CM3679
CM3018
CM3019
CM3020
CM3030
CM4242
UHF
CM4221
CM4228
CM4248
CM4308
MS-1000 SM
GS-1000 SM
VHF/UHF
HD7210P
PR7000
PR7005
PR7010
PR5646
UHF
PR4400
PR9012
PR9016
VHF/UHF
HD7210P
HD7078P
HD7080P
PR7015
PR7032
VHF
HD4053P
PR5030
UHF
HD9065P
PR9014
PR9018
PR8800
VHF/UHF
HD7082P
HD7084P
HD8200P
PR7032
PR7037
PR7052
VHF
HD4053P
PR5030
UHF
HD9085P
HD9095P
PR9022
PR9032
Antenna Direct
UHF
DB-2 SD
DB-4 MD
DB-8 LD
43XG LD
91XG LD
Rick
