Well, it's been over a week that I've been working on my December project - installing a 1.5TB Seagate drive in each of my HR20s (internally).
First, I've owned my HR20s for over 2 years, and they've been flawless. While the units are leased, I'm comfortable with the install/removal methods, I saved the original drives, and will take the risk if I ever need to send the box back to DirecTV (which will be retured to the exact original configuration first, assuming I'm still alive and all).
Opening the HR20 is outside the guidelines of your user agreement with Directv (nuff said).
I ordered two Seagate Barracuda 1.5TB drives for $119 from newegg as part of a Black Friday promo. Since then the drives have been around $129-$139 - so they are still resonable for anyone considering a massive upgrade.
Newegg.com - Seagate Barracuda 7200.11 ST31500341AS 1.5TB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive (bare drive) - Internal Hard Drives
For an external esata solution, this drive is available in a Seagate FreeAgent enclosure for $189.
Newegg.com - Seagate FreeAgent Desk 1.5TB 7200 RPM 3.5" USB 2.0 / IEEE 1394a / 1394b Mac Storage Model ST315005FJA105-RK - Mac Hard Drives
Some HR21 users have experienced problems with FreeAgent enclosures (drives are fine, but not in the external factory encloure). Another solution is to use the 1.5TB drive in an Antec enclosure (typically $49), which has been throughly tested by users for HR20 & HR21 - and works good:
Newegg.com - Antec MX-1 USB2.0 & eSATA External Enclosure - External Enclosures
Now that that's over, let me tell you about all the trouble I had setting up these drives.
First - I had to format the drive on the HR20. No good - wouldn't do it.
Attaching the drive to the sata port (internal or external) and powering the receiver generated a "Drive Failure" message. It asked to try a reboot, which would format the drive, only to return to this same blue-screen.
See the attachment for the error screen.
The HR20 WILL NOT format the 1.5TB drive.
So I tried it in the HR21 - and it DID format the drive - with no problem at all. It should be noted the HR21 runs a later version of the base linux OS built into the box (not the firmware) than the HR20. Other testing has shown the HR20 will not work with drive arrays over 2TB, yet the HR21 will (another clue).
After formatting the drive in the HR21, I reattached it to the HR20 - and it worked! It booted, formatted during the "step 1 of 2" phase, and arrived with a blank drive.
