Hey everyone,
I have lurked for a while and now need some help. The forum has answered a ton of questions when I needed it and I found them fine with doing a search but alas I now havent found anything about this.
Can I use a dish 500 with dual LNBs to set up my hopper in my RV?
I also have 2 TVs in the RV and want to run one with the Joey.
I did set up my cabling in the RV to run the duo receiver when I had it and it worked fine. Now I upgraded to the Hopper in the house and want to take it with me in the RV.
Heres a run down of what I have for the Hopper. I have the Solo Node attached to the dish with both LNBs running to it. I then capped off the one output and ran the other output into the RV. (the RV does have RG6 cable in it) I then ran inside the RV to a tap then the output host to the Hopper and the the client output to the Joey. (in doing a search on this forum this is the correct way to set it up. for my RV and did it this way this past weekend)
I was camping this past weekend and couldnt get a satellite signal from the Dish so the Hopper was a no go for the weekend. (I do have an Accutrac Pro 22 to get the signal and could only get a 30 signal on that finder which wasnt good enough to get the Hopper to work)
Is there anything you guys see that Im not doing correctly?
Thanks in advance
fixit5561
Thanks in advance
fixit5561
