C Chavez SatelliteGuys Pro Original poster Apr 26, 2008 185 0 Milky Way Apr 26, 2008 #1 I have a 722 that when it is in single mode the picture on the TV is full screen, but when it is put on dual mode the screen shrinks on the left and right sides. What can I do to correct this?
lakebum431 Pub Member / Supporter Pub Member / Supporter Lifetime Supporter Sep 5, 2005 17,064 4,990 Norris, TN Apr 26, 2008 #2 I assume you are talking about TV2. Just use the * button to "stretch" the picture to fill the screen
C Chavez SatelliteGuys Pro Original poster Apr 26, 2008 185 0 Milky Way Apr 26, 2008 #3 The problem is on TV1, will the same solution work?
lakebum431 Pub Member / Supporter Pub Member / Supporter Lifetime Supporter Sep 5, 2005 17,064 4,990 Norris, TN Apr 27, 2008 #4 How do you have TV 1 connected? Changing modes should have no effect on TV1.
C Chavez SatelliteGuys Pro Original poster Apr 26, 2008 185 0 Milky Way Apr 27, 2008 #5 I used the Y Pr Pb High Def Analog Outputs and hooked into the component video input on the TV.
vegassatellite SatelliteGuys Pro Pub Member / Supporter Nov 5, 2007 3,319 174 Phoenix, AZ Apr 27, 2008 #6 Try pressing menu 6, 8 and see what the settings are. If you have a widescreen TV, you should change the settings to reflect 1080i and 16x9.
C Chavez SatelliteGuys Pro Original poster Apr 26, 2008 185 0 Milky Way Apr 28, 2008 #7 Thank you, problem solved!
