So what can we here all do to get Dish to fix this black screen with audio problem already? It's been months!! Can you help us Scott?
Dirtydan said:Are all you people using hdmi to connect?
Dan
llars said:I have had a 622 for about a year and a half and since the update that changed the look of the guide my DVR has sucked ass. I regularly get channel signal loss messages, never did before the update. I get the black screen freeze issue still even after this last update. My #2 remote regularly refuses to work even if I put it directly in front of the 622. Are these other symptoms of the newer firmware? My DVR ran perfectly before the update.
Try switching the sat cables and see if the losses switch to the other tuner. Also it could be a failing dish pro separator that is causing your signal loses. I have had that happen before and had to replace my separator. I also have had a diplexor fail and caused me problems. I use diplexors for my sat and ota cables and from the sat side I run one to my separator. One failure in the mix and I lose signals on my sat and ota. If that isn't the case, try to get the 622 replaced because it sounds like maybe a software download caused some problems for your receiver.
I had the problem with tuner 1 of 622 losing video but keeping audio on certain channels. Dish sent me another 622 and now it is doing the same thing. Still have software version 630. Reboot will fix it but that is a pain. Just wanted to check the boards to see if this is an ongoing problem before calling Dish again.
Try this next time ANY of you get the black screen, but still have audio: Hit the 6 second back button on your remote, and see if the picture comes back. It does for me, and I've had this "black screen with audio" problem for YEARS on my 622.
I got the black screen with audio again tonight. This didn't work for me either.Try this next time ANY of you get the black screen, but still have audio: Hit the 6 second back button on your remote, and see if the picture comes back. It does for me, and I've had this "black screen with audio" problem for YEARS on my 622.
