622 Installation tomorrow.
jokeworm
1,118
Tulsa. Ok.
Ok, so after many many hours of fighting with dish CSR's I am finally setup to switch one of my 211's (in the den) and my 311 (in the spare bedroom) with a 622 :)
Install will be tomorrow between 12 and 5. Well that's the plan anyways.
Installation of the 622 should be straight forward in the Den i guess ... just switch out the 211 that is already there with the 622 that they are bringing. What i am unsure about is how they then get the signal to the spare bedroom.
Do they have to drill another couple of holes in my wall to go out from the 622 and then across to the spare bedroom .. or can the existing cables that are already installed be used in some way ?
I currently have a dish 1000 - 110, 119, 129. To a DP34 to Den, Bedroom, and spare bedroom.
What else should i be looking to check before they leave to make sure its all setup correctly .... ? I have read that the 622 can be set to either TV1 or TV2 .. given that the spare bedroom is hardly every used .. which setup would i be better off using ?
Thanks in advance for any tips.
channel 5749 FVOD
