The terminals on the Gbox and Actuator are a little small for #14 AWG . Smaller wire is a better fit.
Thanks BrentNice looking dish, Stan, but I think it needs some camo paint !![]()
Is your mount a non-penetrating mount? Can you take a picture showing the base of your poll mount? Where did you buy it and how much did it cost?I have my 24" actuator set up on the right side and get satellites from 30w to 137w with my south satellite being 72w here in Ct.I needed to have my actuator clamped near the end by the piston to get this range.When the actuator is all the way in im just barely at 137w.The weight of the dish can put a bit of strain on the actuator near 30w! so i do move the dish slow in this area.I use satellite c-band ribbon cable hooked up to my actuator!the cable isnt cheap!it cost just over 1$ a foot and the motor wire leads are pretty thick and just barely fit into my cheap v box connectors.Heres a pic of my actuator set-up.
Is this what your looking for?Is your mount a non-penetrating mount? Can you take a picture showing the base of your poll mount? Where did you buy it and how much did it cost?
P76:* Pole Mast for Polar Mount Style SD180PM Sadoun 180CM Prime focus Satellite Dish This is what i have!bolted on my deck.
Thanks guys!!This is what I'm using. See rest of pics on page 14 of this thread. Bought it here. It's the "Roof Mount - Non-Penetrating for large offset dishes". Worked very well on my 1.2M offset. I got a custom pipe fabricated by a local shop to give it a bit more height. Used PVC pipe to snug up the mount as described by dougruss on page 1.
I now have my 13' pole planted dish on what an ordeal that was............ I am having problems attaching my WS-KU2C conversion bracket and conical scalar ring supplied to the 3 feed horn poles. The three mounting holes on the ring are 45 degrees off from the poles. I have observed everyone else has a flat ring to mount their LNB to. I have a DMX741 LNBF and was told when purchasing this was the ring I needed. HELP
Rodm
Hi, Doug and Brent THANKS for the quick reply. I will use the flat ring that came with the LNBF. Wonder why they told me at WSI that I needed to buy the conical ring,,,,,, Back up the ladder I go. I
