D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 6/25/2009 2:14am - 42 changes
Uplink Comparison Range: 06/25/2009 01:59A - 06/25/2009 02:13A
Channel Removals:
6151 - LTD14 (NA) removed from EchoStar11 110W TP 19 ConUS beam
6154 - LTD17 (NA) removed from EchoStar11 110W TP 19 ConUS beam
9584 - LTD4 (NA) removed from EchoStar11 110W TP 19 ConUS beam
Channel Moves:
151 - VS. [MPEG2 SD] moved from EchoStar11 110W TP 01 ConUS beam to EchoStar11 110W TP 21 ConUS beam (A)
155 - FUEL [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 15 ConUS beam (A) (H)
177 - TOONW [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 05 ConUS beam (A)
181 - N [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 11 ConUS beam (A)
198 - SLTH [MPEG2 SD] moved from EchoStar11 110W TP 09 ConUS beam to EchoStar11 110W TP 01 ConUS beam (A)
217 - IONW [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 01 ConUS beam (A)
233 - NOTAX [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 01 ConUS beam (A) (H)
267 - CTN [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 09 ConUS beam (A) (H)
402 - NBATV [MPEG2 SD] moved from EchoStar11 110W TP 01 ConUS beam to EchoStar11 110W TP 09 ConUS beam (A)
403 - NHLN [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 15 ConUS beam (A)
511 - PPV [MPEG2 SD] moved from EchoStar11 110W TP 16 ConUS beam to EchoStar11 110W TP 14 ConUS beam (A)
512 - PPV [MPEG2 SD] moved from EchoStar11 110W TP 16 ConUS beam to EchoStar11 110W TP 14 ConUS beam (A)
560 - NBATV [MPEG2 SD] moved from EchoStar11 110W TP 01 ConUS beam to EchoStar11 110W TP 09 ConUS beam (A) (H)
625 - NHLN [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 15 ConUS beam (A) (H)
834 - PSNES [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 16 ConUS beam (A)
848 - CBBIS [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 16 ConUS beam (A)
867 - BDMAX [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (A)
5801 - SKDL [MPEG2 SD] moved from EchoStar11 110W TP 16 ConUS beam to EchoStar11 110W TP 24 ConUS beam (NA)
5812 - SKDL [MPEG2 SD] moved from EchoStar11 110W TP 16 ConUS beam to EchoStar11 110W TP 24 ConUS beam (NA)
6152 - LTD15 [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 11 ConUS beam (NA)
8025 - KPXN [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 01 ConUS beam (A) (H)(San Bernardino, CA-N/A)
8909 - KPXO [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 01 ConUS beam (A) (H)(Kaneohe, HI-ION)
9399 - CTN [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 09 ConUS beam (A) (H)
9581 - LTD1 [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)
9582 - LTD2 [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)
9583 - LTD3 [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 09 ConUS beam (NA)
14452 - KOMO2 [EPG] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)(Seattle, WA-ABC)
14468 - KXNE1 [EPG] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)(Norfolk, NE-PBS)
14469 - KXNE2 [EPG] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)(Norfolk, NE-PBS)
14470 - KXNE3 [EPG] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)(Norfolk, NE-PBS)
14471 - KXNE5 [EPG] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)(Norfolk, NE-PBS)
14601 - KSIN1 [EPG] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)(Sioux City, IA-PBS)
14619 - WGCL2 [EPG] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)(Atlanta, GA-CBS)
14620 - WGCL3 [EPG] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)(Atlanta, GA-CBS)
14622 - WXIA2 [EPG] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)(Atlanta, GA-NBC)
14769 - KIMA2 [EPG] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)(Yakima, WA-CBS)
19215 - HUNTT [DATA] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 09 ConUS beam (A)
19216 - HUNTV [DATA] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 09 ConUS beam (A)
Transponder Changes:
EchoStar11 110W TP 19 ConUS beam changed from 20000 QPSK 7/8 to 21500 8PSK 2/3
Channels in the system: 6559
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Channel Removals:
Channel Moves:
