522
davev
17
How can I hook up a 522 to operate 1 tv with just one cable from the sat.
I have a dish 1000. Two cables from the dish one to a 722 the other to the 522. Here is the problem, no matter how I connect this line to the 522 it doesn't work. Two calls to tech support with no results. One says it can't be done the other says he will send a tech out to the house but will have to charge me. Any suggestions?
can you give more details on what you have. is your dish 1000 have DPP twin or is it dish 1000.2? on what ports on the LNB you are hooked on? are you using separator properly? what does your check switch says?
Must be Bad Karma, 522 Hesitates Momentarily Sometimes
E* website program guide
