Hi all,
Latest fiasco wound up in a room mate disconnecting the 322 to stop the other room mate from getting tv. (he could have just taken off the antenna).
Anyway, it's my account, and after those two sorted things out, the 322 was re-connected and now is doesn't work.
TV1 screen only shows "press select to continue" and that's it. This box gave some problems when first connected and then again when they came to move the dish. It would stick at the "acquiring signal" screen and took serveral re-sets to finally get going.
The one room mate called in and went through tech support. They told him the receiver is bad and a new one is being sent. I do know that when it was disconnected that it wasn't abused, but it did not sit for 2 minutes. The guy unplugged everything and picked it up immediately.
Bottom line is that they said there will be no charge if there is no physical damage. Could that disconnect be called physical damage? Would handling it too soon damage the HD to the point that I have to pay for it and remove the other units in the house?
Tim
Tim
