Hi Everyone,
I tried to hook up a third Directv receiver today and I'm running into some problems.
I have a 3 LNB oval dish with two lines. I had two Directv receivers connected, one to each line, using diplexers. I receive the main Directv programming from one satellite and local channels from another. (I believe the third is for HD programming which I don't receive.)
I tried to hook up a third receiver today using a 3x multiswich and now two of the receivers can't receive the local channels. The receiver that can is missing other channels.
The answer seems to be that I need to run two more cables from the 3 LNB dish into a 4x, 5x, or 6x multiswitch so that each receiver can switch between the two satellites.
What I don't get is why was the 3 LNB/2 line setup working with the diplexers? Is it because I only had two receivers connected?
I know this has probably been discussed several times, but after an hour reseraching the net (and pouring through FAQs), I'm still not able to put all the pieces together.
Any insight you could give me would be greatly appreciated.
