211 seems borked
drfrink24
Hello all.
I'm running both analog (temporary sound until I setup 5.1) to a TV, and component to an Infocus IN72 projector. I had a DVD player hooked up for a demo to a buddy, and after he left, I powered down everything, and switched back to the 211 component. After bringing everything back up, the projector wasn't picking up any signal from the 211, and the analog picture looked like a slightly out of tune OTA channel .
I soft-powered down the 211, no change in both the HD out (none still), and the analog out actually got worse. I then unplugged the 211 for a few minutes, came back, powered everything back up, and now the analog output is 90% static, with no HD output. I can see slight changes in fuzzyness (audio has been absent as well) when I change channels or bring up a menu, but, HD out is nothing, no audio, and analog is basically 90-100% colored static.
All other recievers in the house are working fine. Its also my understanding that if I lost signal, the TV would look fine, it just would say its trying to aquire sattelite.
Any ideas? Maybe ventilation, as I had just placed the DVD player on top of it about 1hr previous to this, and it seemed pretty warm/hot... I have not tried it since last night, if it works today, it may be a heat issue.
Grounding?? - Want to make sure installer told me correctly
622 L3.60 Software Release Notes
