20.1 remote for IR?
KAB
21,995
5,725
Fishers, IN
Can it (TV2 722K) be set up for IR? On the old remotes you could flip the tabs, but does not apply to the new ones?? ALSO, TV2 remote will not control TV1 in Single Mode, so I seem to have a problem somewhere. Addresses are OK.
Tech Portal : Remotes : 21.0 IR/UHF Pro
All IR/UHF remotes also send IR commands in SAT mode.
If, for some strange reason, you want to use the UHF remote in IR mode with TV1, you just need to change tabs. Look around in the above referenced Tech Portal information.
Actually, there is a switch I just found in battery compartment, IR/UHF. That did it.
Dish 500 locked on 119 & 129
Problem with using DVR functions and audio/video skipping
