2 tv 1 reciver and satrlite and cable conected
sokol605
usa
I have satelite service and one dual dishnetwork reciverDVR625 hook up to 2 tv( one is remotly)
I thinking adding cable service to both TV.One of tv is easy to conected cable and sat thru reciver .How I can conected two lines : cable and satelite to second TV.
This TV have only one coax outlet ,sombody mention me about A/B switch but this switch manualy has to change from cable to satelite.It is better way to do it?
First off, don't assume that you can share any cables.
Connecting cable and satellite at the same time may require some extra hardware. It may be necessary (almost likely) that you'll need a device that filters out a frequency for you to put your satellite feed into the mix.
Is there something in particular that you need cable for?
If so, does it require a "digital cable terminal"?
211K = death
UNIVISION TELEFUTURA AND GALAVISION
